Scotts Company Scotts Lawns  Edgeguard Deluxe Spreader Logo
Posted on Feb 17, 2011
I need spreader setting to do 2.3 pounds per 1000 sq ft
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Feb 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
59128
Points
89
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
We do have a general rule, called the 50 by 20 rule which will allow you to use any product in any spreader, but there is some work that will need to be done.
* Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (In your case 2.3 pounds)
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less. In your case i would suggest about 2.75 or 3)
* Spread the material over a 50 x 20 ft. area (This is 1,000 sq. ft.).
* If material is left over, you will need to increase the setting accordingly
* If they you up short, you will need to decrease the setting.
1 Related Answer
Anonymous
  • Posted on Oct 24, 2010
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
I have a scots edge guard spreader and need to put on weed and feed at 4 lbs per 1000 sq feet what setting on spreader should I use
Hi Mike:
The setting will depend on the size of the weed & Feed pellets.
The package usually has setting instructions on it.
If all else fails, the rate is 1 lb per 250 square feet.
Mark out an area about 10 ft by 25 ft long.
The spreader cast is about 5 ft, so down and back should use 1 lb.
Set the spreader at a minimal rate and see how far 1 lb goes, then adjust the setting accordingly.
2answers
Ez republic broadcast setting for expert gardener St Augustine Weed and feed for southern lawns
The bag should have a phone number for customer support. They would be the ones to give you the conversion rate for your spreader. How many square feet are you treating?
www.naturewestinc.com
2helpful
What are the settings for 5 lbs. 1000 sq ft on a scott speady green 2000
the low end od the stting bar is for 1/2 pound per thousand sq ft each mark adds 1/2 pound
4helpful
5answers
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 • Garden
3helpful
What would be the setting to cover 4 pounds of product per 1,000 square feet? Scotts Drop Spreader PF4 Precision Green.
Unfortunately, because granular products come in many different particle s and densities, there is no way to determine a universal pounds per thousand spreader setting. The only solution would be to do a 50 foot by 20 foot test. The 50 by 20 rule will allow you to determine an appropriate pounds per thousand rate for any product in anyspreader, but there is some work that will need to be done. *Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (Inyour case 4 pounds) *Place the spreader setting on a low setting about 1/4 of the way open. * Apply the 4 pounds of material over a 50 x 20 ft. area (This is 1,000 sq. ft.). *If material is left over, you are underapplying, and will need to increase the setting accordingly; before applying to the remainder of the lawn *If you come up short, you are over applying and you will need to decrease the setting; before applying to the remainder of the lawn
2answers
I have a speedy green 2000 broadcast spreader and need to know what setting I need to use to spread 40 lbs per 2000 sq ft dolomite peletized lime? Thanks.
first 40lbs per 2k of lime will do nothing, rate to chemnge ph 1 point is 50lbs per 500k which would be all the way open slow walk. for your application you should be about half to 3/4 open normal walk
I have a Scotts Speedy Green 2000 rotary spreader and want to know the proper setting for your Milky Spore 20 lb. bag (granular carrier). I have been keeping it about 50% open (Setting # 9 to 9.5) but it...
I have the same question, but have not found a direct answer. I have calculated an estimate setting of 4 or 5 for the speedygreen 2000. The Milky Spore is very simular to the fertilizer that I use. Milky spore says that 1lb covers a little over 300 square feet. My fertilizer says that at a setting of 4 it is spreading 2.6 lb per 1000 square feet (almost 3 lb per 1000 sq ft or 1 lb per 333 sq ft).
Now I may be totally off, but just bought the Milky Spore today and will apply tomorrow. I may look some more tonight to see if I can find an answer. I felt it was kind of bad that the back of the Milky Spore suggested only using a drop spreader!?
8helpful
2answers
What setting do I use on the Scotts Mini Spreader?
Here is the rule of thumb to determine your spreader setting.
Place enough material in the hopper to cover 1,000 sq. ft. (Usually indicated on the bag of product, if not indicated, take pounds in bag and divide by the number of thousand square feet bag covers. Example: 23lb bag covers 5,000 sq ft, divide 23 by 5 to get 4.6lbs per 1,000 sq ft).
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less).
* If material is left over, they need to increase the setting.
* If they come up short, they need to decrease the setting.
* While this is not a scientific method for getting the spreader setting, it will be close.
Top Scotts Company Garden Experts
Jay Finke
Jay Finke
john h
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
