Importing HD from Sony HRV-A1E, Glitches in timecode at random points which drop audio and footage data. Same problem on several tapes. Fact that the glitches are in different places points to it not being a problem with the tapes. Also we've tried two different cameras (same make). Using Macbook Pro and iMovie HD/9.
Thankyou!!
Hi, Try to playback with other tape recorded earlier from other camera or VTR .If other tapes are palying properly without any glitches then it might be the problem with this recording.
no ,but you will have a dvd quality picture. HD means
the picture size format usely 16:9, HDMI its a Hd
multimedia interface its HD quality to...
hope that help you..
Unfortunately, the outlook is grim. If you duped the tape and the dropouts still appear, the anomalies are regrettably on the master itself, or the DSR11 is malfunctioning.
To be sure, try the following:
View the master tape on a different deck, if possible. If glitches vanish, problem solved. Connect the AV/RCA out to the input on whatever digital deck you're using, and capture as usual with FCP. (If you need assistance with this step, I'll be happy to walk you through or send you in the right direction) Optimally, for a Hi8 tape, you would capture using DV 60i settings.
If glitches still appear, try capturing audio and video in two separate occurrences, I.E. One capture for video only, and a second capture for audio only. Sync in final cut.
If that doesn't work, your other option is to send the tape out to a post production house/lab, and see if they can do it - but if you've tried everything else and resorted to this option, the chances are slim that much can be done - Hi8 tapes are notoriously difficult to recover. Best of luck, and do let me know I can be of further assistance :)
Unfortunately solution #1 is incorrect. Many Sony Hi8 camcorders had the ability to store timecode information on the tapes. My TR3400 is one of them. It is not stored in the same way as the newer digital cameras, but it is there nonetheless. It is not permanently imprinted in the picture either, it can be turned on or off at will during playback if you chose to date stamp your footage when you took it (it was optional). See this list for a partial list of cameras that did support it: http://en.wikipedia.org/wiki/Rewritable_consumer_timecode.
I have had my hopes that the Digital8 cameras could provide the required translation to DV timecode, but I keep hearing conflicting reports, typically the answer is no. There is a third party product that was created to help solve this problem though: http://www.octochron.com/faqSonyHi8RcTimeCodeDataCode.htm. It is not particularly cheap but if you really need the timecode it looks like the only real alternative at this point. I have not used it myself yet, but may have to as well.
I think you may have misconfigured something because the problem is not in your DSR-11 try connecting it to a monitor and you will see the time stamp and picture as proof of what I am saying. The problem I think is that your Mac is not processing the time stamp correctly.
Try this link first it helped me:
Remember follow the instructions ezactly:
http://forums.creativecow.net/readpost/35/856108
