Does your machine have a knob on the side of it which controls hot water and steam?? Depending on which model you have it Sounds like it needs a new ceramic valve. This is the valve operated by the round switch on the right side of the machine. Maybe remove the switch first and check the actual function of the valve to make sure its not the switch slipping. If the ceramic valve is at fault, they are very easy to replace.
Leave the wand in place and disconnect the teflon hose that connects to the wand then press the steam button again.. check presure... you could have a bad steam valve
