Microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently.
Hi
F3 error in your GE microwave
means that the keypad/touchpad is bad and should be replaced. However, before
replacing it you can follow these step by step instructions to clean the
touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting
circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover
moisture
8) After this put the keypad back
if its not solved then replace it.
Hope this helps...please post back
for further assistance.
Daniel
Same problem, need some help please!
F3 +beeps + no buttons active
GE MICROWAVE Model no JES831WB 001 SHOWS F3 IN LCD DISPLAY WITH THREE LOUD BEAPS , NO EFFECT OF ANY KEY ON TOUCH PAD , EARLIER I FOUND THAT THE CLOCK WAS RUNNING VERY VERY SLOW ABOUT 13 SECONDS PER MINUTE.
