Link below found using
https://www.google.com gives steps to follow:
https://www.intel.com/content/www/us/en/support/articles/000005740/boards-and-kits/desktop-boards.html
PXE-E61 Media Test Failure Error for IntelĀ® Desktop Boards
Documentation
Content TypeTroubleshooting
Article ID000005740
Last Reviewed11/01/2017
What are you seeing?
The following errors display when your IntelĀ® Desktop Board starts:
- PXE-E61: Media test failure, check cable.
- PXE-M0F: Exiting Intel Boot Agent.
Why are you seeing it?
PXE (Preboot eXecution Environment) is a boot environment that allows the Intel Desktop Board to boot up using a network interface, instead of booting from an installed hard drive. You can enable or disable PXE boot in the BIOS.
If PXE Boot is enabled in BIOS, the PXE-E61 and PXE-M0F errors can happen when both of these are true:
- A bootable hard drive is not detected.
- A network cable is not connected to the Intel Desktop Board.
How to fix it
If a drive is installed
Check that the drive is detected in BIOS:
- Press F2 during boot to enter BIOS Setup.
- Go to the Boot menu.
- Check the Boot Drive Order.
- Press F10 to exit BIOS Setup.
If Boot Drive Order shows
No Boot Drive:
- Check that the drive is properly installed in the computer.
- Try installing a different known good drive.
To check the BIOS option:
- Go to the Boot menu and check for Boot to Network.
If you do not plan to boot to a network, disable this option.
If you do want to boot to a network, check that the network cable connection is working properly.
