SanDisk Sansa e260 MP3 Player Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How install a driver for Sansa e260 - SanDisk Sansa e260 MP3 Player
Joe Negus
Level 2:
President:
  • SanDisk Expert 652 Answers
  • Posted on Feb 17, 2011
Joe Negus
SanDisk Expert
Level 2:
President:
Answers
652
Questions
Helped
165717
Points
154
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Anonymous
Level 2:
New Friend:
  • Expert 82 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
82
Questions
0
Helped
17960
Points
299
Connect the Sansa E260 to your computer using a USB cable. Plug one end of the USB into the MP3 player and the other end into your PC. Click on "My Computer" on your computer and open the SanDisk folder. This is the folder for your Sansa E260. Locate MP3 music files on your computer. These may be kept in the "My Music" file on your computer. Click on the "Start" icon to access music files. Click on MP3 music file you want to transfer to your Sansa E260 using your computer's mouse. Once the file is selected, it will turn blue. Drag the MP3 music file into the SanDisk player folder. Repeat process until you've added all the songs you want onto your Sansa E260.
5 Related Answers
Anonymous
  • Posted on Jan 02, 2007
SOURCE: Sansa e260 says connected but device not recognized
I agree with the above suggestion. Try setting the USB Mode under "Settings" on "MSC" on the Sansa. My computer would not recognize the e260 when the mode was set to "MTP"; works fine on "MSC".
Anonymous
  • 155 Answers
  • Posted on Oct 09, 2008
SOURCE: where have SANSA E260's drivers
Update the firmware of the player.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Dec 17, 2008
Substitute REC fo volume + in the following:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Schmead10
Joe Negus
  • 652 Answers
  • Posted on Jun 09, 2009
SOURCE: sansa e260 player not recognized by window
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) . download and install Copy and paste click run to install follow instructions make sure your sansa is in msc usb mod in the settings in the sansa
  • 102366 Answers
  • Posted on May 28, 2010
SOURCE: on whaich site i can find Sansa e260 Software for free
The manufacturer's web site at http://www.sansa.com has drivers, software, and manuals.
Cannot find driver for sansa sandisk 4 gb e260
Hi cream_soda21,
There are no drivers needed to be installed because Sansa Sandisk is a plug and play device. However, if your device can't be recognized by the computer, please consider visiting the link below. Please follow the step by steps procedure.
Sansa player not recognized by the computer
Hope it helps.
Thank you for using FixYa.
2helpful
On whaich site i can find Sansa e260 Software for free
1helpful
How do i update my SANSA e260 4GB, firmware??
1. Download the SANSA Updater from:
http://www.sandisk.com/sandisk-support/driver-download-wizard.aspx
2. Install Updater
3. Plug in the SANSA e260
4. If it needs new firmware, it will tell you to download and install.
5. Follow directions on screen.
2helpful
2answers
Lost instalation cd
If you need the CD, you need to contact the manufacturer to mail you the CD. But, you may check the link below and download the software/driver for Sansa E260:
http://www.drivers.mrjuan.com/driver-5947-sansa-e260.html
Have a great day!
3helpful
2answers
Sansa e260 player not recognized by window
E260 Vista SP1 Drivers
You should be able to access it as a flash drive straightaway; yes, the Sansa.com site has drivers on it.... But keep searching the web on
  1. Vista SP1 Sansa Drive Mount
...and try changing the Sansa between USB modes.
2answers
Sreen froze on refreshing data
direct us to the drivers needed to install unit on pc thanks sansa e260
11helpful
4answers
Where have SANSA E260's drivers(xp) EMAIL:[email protected]
Go to this site (sandisk's website) and select Sansa
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
