Does the key not turn all the way back when it gets stuck? If the key gets stuck and won't turn all the way back to lock position, chances are the tumblers in the ignition switch are going bad.
some of these electric interlocks require the brake pedal stepped on for releasing..have you tried that? along with shifting fully into park a few times?
try wd40 and shaking the key, what happens is one of the tumblers get stuck and wont let the key turn if that dosnt work let me know worst case you will have to replace the ignition its about $35 to $40 and a few hours.
Did u try turning the steering wheel slightly in either direction? The steering wheel can 'jam' causing the key to seem stuck in the ignition. Simply turning the steering wheel a bit relieves the pressure and the key will turn. Let me know if this works for u
