Hello and Welcome to FixYa!
You need to have the Data Cable for this. If you have the cable download this update utility. Download, install and run the application. Follow the one screen instructions to update your firmware. At one stage the software may prompt you that your firmware is up-to-date, proceed anyway? At that point you have to force it to reprogram.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Ok got a experia sonny ericson from roger and every thing is working fine but wene i make a call now my screen goes all blackk i touche eny botons dont screen don comm back on but the personne is still on the line i cant talk with them but afther the call is done done phone screen is still black i have to remove my batterie and put it back in and restart the phone afther every phone call i answer or make !!plzzzz help wit this thank you in advance !!!
When i turn on my x10, its keep vibrating and the screen appear nothing...its stop vibrating until i remove the battery...what is the problem?...plz anyone help me...
SOURCE: how do i unlock my sony ericsson xperia x10 phone?
Use this following steps to unlock your mobile
- Switch ON your Sony Ericsson Xperia X10 without any
SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have
displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
And also get the unlock code here theunlockarena.com
SOURCE: sony ericsson xperia x10 unlock code
You can get the unlock code by contacting your current service provider customer care department.If your phone is locked you can use any of your friends phone to make this call. The service provider will then provide you the unlocking codes.. Remember that the reason why the codes are provided only thro customer service provider is they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides unlock codes. All are fake. Only your service provider can provide these codes.
Thank you !!
SOURCE: How to set MP3 as text message tone on Sony
If you want to set an mp3 or "Custom" tone for your "Notifications" you can dowload an app or...
Connect your X10 to your computer. Pull down the usb notification in top left of screen and mount sd card.
Then go into your phone menu via "My Computer" and either go into media/audio/notifications or create the folders yourself. Remember they must be lower case letters.
Then all you have to do is copy your tone into the "notifications" folder disconnect your phone from your pc and go into "Settings" "Sound and Display" "Notification ringtone" and it should now be in your list with the preset standard tones.
SOURCE: is it possible to salvage a water damaged sony
Yes- first thing, remove the battery. Second thing, tilt it on its side so the water drains out. Leave it alone for at least 48 hours. If it is salvageable, it should work once it's dried out
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Testimonial: "quick responce and very good answer I highly recommend"
1. Switch ON your Sony Ericsson Xperia X10 mini pro with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X10 mini pro will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Ericsson Xperia X10 mini pro phone should now be unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Sony Ericsson Xperia X10 mini pro is locked to.
