SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
SOURCE: Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
SOURCE: 32" Sony Wega -- initial set-up menu constantly on
While washing the screen of the tv some cleaner may have got to the buttons and casused some corrosion try pushing the buttons a few times at the front of the tv this usually works if not you need to have one of the buttons replaced..
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
SOURCE: how to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
