Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Anonymous Posted on Feb 17, 2011
Just replaced a burned out lamp but the tv still wont turn on and the lamp light is still flashing? tv model #50V720
Chi Chu
Level 3:
  • Hitachi Master 8,457 Answers
  • Posted on Feb 17, 2011
Chi Chu
Hitachi Master
Level 3:
Answers
8457
Questions
0
Helped
2822955
Points
26282
The tv have clicking sound alot too?Yes,the tv the board that call the Ballast board is dead too.The ballast board only job is to ignite the projection lamp.
  • Anonymous Feb 17, 2011
    no the tv has no sound and the screen is black, but what is a ballast board?
2answers
Color issue
download this manual
http://merchant.satisfusion.com/sf/library/manuals/owners/50V720.pdf
see page 59,60,61,62. The problem can be the lamp
After extended use, if the TV picture turns dark, the color looks unusual or LAMP INDICATOR light turns on, then it
is time to replace the lamp with a new lamp.
1helpful
I have replaced my lamp in my Hitachi 50V720 and the lamp light keeps flashing.
Make sure that the lamp door cover is properly seat-in. It has a safety switch that will engage to the lamp door cover. If the lamp door cover is not properly seat-in this switch will be on open position that will trigger the symptoms.
Hitachi model number 50V720 does not show picture or sound when turned on. The Temp light and the lamp light flash red on and off. What's the problem?
Check the tv fan it is running?No than the fan require replacing.Yes,than the tv projection lamp life are ending require replacing.
3helpful
TURN ON THEN LIGHTS FLASH LAMP LIGHT STAYS ON AND NEVER COMES ON
Need to replace the lamp if lamp still doesn't light after next power on, check the assembly of Lamp unit
2answers
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
TV went off, and three lights come on (green "power", red "temp", and red "lamp")for just a second, in succession from left to right.
My television had two red lights flashing, one for Temp and the other for the lamp. I removed mythe lamp assembly and the bulb filament was burnt out. I order a new lamp and housing unit UX21517 and replaced it and now I have the red light flashing which is calling out the lamp again.
We have a Hitachi model # 50V720 TV. When you turn it on, green power light flashes, then temp and lamp lights begin to flash, eventually goes to just the lamp. Can you guide us as to what the problem may...
Y sus (sustain) board or main power board has dry capacitors or dead transistors or even main chip is dead, but to know more accurately you need to count the red light flashes. Google "red blinking codes" should find the answer, ebay sells Y sus boards or power boards around $125 (cheapest) for plasma TVs.
4helpful
Replaced lamp on Hitachi 50V720, still have flashing red light
Just make sure the Box (Lamp Enclosure) is pushed in firmly on both sides, left and right. Left side to hit the power connection and Right side to hit the little relay switch, Must be flush against that back side. It happened to me and I was kicking myself in the ***, a entire weekend went by with a brand new lamp sitting in the enclosure but not completely set in correctly with a flashing red light.
2helpful
4answers
I have the same model and had the same problem after replacing the lamp. Turns out if the cover plate is not put back on properly, tv will not power on and lamp ligth comes on. To solve the problem all I had to do is tighten the cover plate screw. Hope this helps.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
