Why not ask your ISP (SAT)
what is your SAT provider, we can help lacking a key fact like that.
my guess is you are reading too much, too deep in the text.
if you PC runs ok, then forget that video junk.
forget it.
its and internet connection that works on all PCs.made
it has instructions,
heck most ISP come to you home and connect it. why not you?
s8000 is 16-17 years old.. running what OS.
I bet they dont support your unstated OS, XP?
it came with XP 2001, and needs SP3 to be even useful.
upgading to W7 is super good idea, as XP and VISTA have zero support now.
any
satellite has a modem box.
this box has a Ethernet jack.
you connect it to the PC and it works
the PC has driver on that simple port that always works and is alive.
its just a simple Cat5/6 cable, most modems come with a short cable, or buy one for $5 25ft long, easy,
it can be up to 100 meters long, too. (metric)
all that matters is that Ethernet jaCK
HUGhES NET?????? IM GUESSING YOURS ,WHY?MUST I.
THAT CAT5 CABLE GOES TO LAN JACK
Then boot PC and the ethernet icon on the tray goes to happy.
and IE 6 runs, and finds every virus ever made.
XP has over 700 exploits and is a virsus magnet, the below is the gate way to H3LL and endless pain.
upgrade to w7 now. or pain is unending later.
Yes, It has a VGA connector. Not sure exactly what cable you need.
SOURCE: VGA DRIVERS
Here u go:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=240900&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=240898
And if u got help rate me as FIXYA PLEASE?
SOURCE: Can I Connect a HP Pavillion BF52 10/2003 Flat Screen Monitor to a Compaq Presario 5000 Series
Sure any monitor will work on your compaq
here is a link to the video cable you will need
http://www.computercablesource.com/svga-video-cable-003-foot-super-shielded-hd-15-male-to-male-high-resolution-84.html
I hope this helps
SOURCE: I need drivers for the following
Download the drivers from Compaq site here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=ca&lang=en&product=3739727&
SOURCE: Have old compaq Deskpro EN ENS815EC733 M1BU
I would buy a cheap usb card to fit into a pci slot on the old computer.
Otherwise you would need a serial cable (if your laptop has a serial port) if not it would be a serial to usb plus the software to transfer, i would say far too much trouble.
A usb card is a couple £/$
http://www.google.co.uk/products/catalog?hl=en&q=pci+usb+port+card&um=1&ie=UTF-8&cid=13689229979239224585&ei=5RBCTMCBCIyOjAfu8eUV&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDAQ8wIwAg#
SOURCE: VGA driver is not found
You can download the video drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model desktop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
