I have a Toshiba Satellite laptop. The power light is on but it does not work. I tried unplugging and removing the battery, but the problem remains. I don't hear anything and the battery light is not on.
Try reseating the ram memory. If this does not work then try using new ram.
From Chris@itechcomputing
Solution: Toshiba Satellite C670
Noticed plug light was on front left ( orange )
Noticed power light turned on Green
but still was not booting.. after removing the ovious - HD, RAM, and checking the power adaptor... nothing ... pulled the battery -- and plugged in... and BINGO.... Found problem... Faulty Battery./..
Have a good day... hope this helps someone
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
hi , my name is vivin uppar.......
my laptop is not working.... the problem's same as mentioned by asheri...
the power indication light is on when i press 'power on' button, but computer doesnt run.... and on connecting to the ac power supply... the battery light (which when working normally, is orange if not completely charged and blue if it is charged completely) doesnt lit only....
also i took of the battery and tried running from ac power supply alone, even then it's not turning on....
i also tried (fn + f5) to change he display settings , which i saw in other blogs.. but that doesn't solve either because my laptop is absolutely not running......
please try finding a solution for this....
I have the exact same problem, The power light is on but the laptop does not power on. I also tried unplugging and removing the battery, but the problem didn't go away.
