The Parental controls for your DVD player has been turned on. The default setting for most Parental Control setup is G rating meaning that anything above a G rating will not play unless the override code is entered. I was unable to locate a copy of your manual, but if you look in your copy for a heading called Parental Controls, it should explain to you what has to be done to either change the rating or remove the control altogether. Unless you have small children that may use your player you can probably remove the controls altogether. Normally you would have to go into your Setup menu, and then look for Parental Controls in that menu. Unless someone setup a code, you should be able to go in and just turn it off. If there has been a code applied and you are unable to find out what it is you will have to contact Memorex support to find out how to remove it. To ensure that it doesn't get turned back on you might want to hide your remote, as you need to use it to turn the feature on and off.
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
