You either have a bad LCD display OR the connection for the LCD display is loose/off. Its impossible to tell what channel you are on with a 2950 without the screen working, but when you turn the channel knob do you hear any other cb transmitting on ANY channel?? This is a tough one!! I really need some more info on the radio.
Open the case and look at the area that the display is in (front of radio). Slightly wiggle all of the little plugs in that area. If you see the LCD screen come on or flash then you know where your problem lies. If not, then you're probably looking at buying a LCD display for the radio.
Good luck.
