SOURCE: Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
SOURCE: Mitsubishi WS-55513 screen keeps turning off
Yes, if you are handy, you can leave an e-mail address and I can send you a how to do repair guide with the factory service manual for your TV set and you will save at least 800 to 1000 bucks!
SOURCE: My TV shuts itself down by itself
Agreed, one of the problems is power supply problems, also, overheat protection may also be the cause, make sure the internals are dust free, compressed air works wonders, remove the back cover, blow as much of the dust as you can off of the componants, replace the cover, and see what happens...
NOTE: If you are using a home / shop air compressor, make sure to have a vapor filter to remove any moisture from the air lines. water + electronics = BAD
SOURCE: try to turn on shuts down right a way ws_65809 7yrs old
You may just need to replace a few components in your tv or there mmight be something loose. First part of the TV that usually shows up with a problem is the power supply. Check the power supply for loose soldering or leaking capacitor. If there are none on those circuit make your way up to the main board and have it checked.
SOURCE: I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
