Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
My computer not recognized the device Lexicon Lambda, cannot install the drivers. Windows 64 bits. I7. Thanks
SOURCE:
SOURCE: lexicon lambda
push the monitor button to go mono instead of stereo.
Posted on Nov 29, 2007
SOURCE: My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
Posted on Apr 11, 2008
SOURCE: lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
Posted on Jul 26, 2008
rob151
  • 54 Answers
SOURCE: Lexicon Lambda not detected
the usb could be the problem. when you plug it in does your comp make a noise if not it is the usb if it does than the drivers are not in sometimes its a program problem try going to start-mycomputer-(cd/dvd drive right click on it and click explore. find the file labled drivers and install them first than install the program hope this helps.
Posted on Jun 29, 2009
  • 102 Answers
SOURCE: I had a lexicon lambda installed on my old laptop.
Hi here is a link to the drivers for you Lambda.>
http://www.lexiconpro.com/product.php?id=8#downloads
Thank you for using Fixya.com
Posted on Feb 10, 2010
Lexicom Lambda is not working! New user
right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
I have a lexicon omaga drive but when i hook it up its like i need a 64 bit driver
Don't know what OS you're running. Omega has published drivers for Vista and 7 64-bit versions. They say they don't support XP 64, but when I hooked my unit up to my computer and the hardware install wizard came up the OS found and installed Microsoft published general USB audio device drivers for all inputs, midi, and mac USB channels of the Omega, and automatically set it as my default device. I hooked headphones into the Omega unit and could hear system sounds. So far so good. Went to My Music and fired up an audio file. Windows Media Player started up and the song started playing but I couldn't hear anything. Opened the same file with Audacity, could see the VU meters bouncing, but still no sound in my headphones. Went in to the preferences of Audacity, and manually set the speaker default to the Omega mac USB device. Hit play again and voila! I had sound. Closed the file, started WMP manually, went in to options, and again set the speaker default to Omega mac USB. Opened the same audio file and this time it played just fine. The driver files Windows used for my card were
C:\\WINDOWS\SysWOW64\ksproxy.ax, C:\\WINDOWS\System32\drivers\ks.sys, C:\\WINDOWS\System32\drivers\ksthunk.sys,
C:\\WINDOWS\System32\drivers\portcls.sys,
C:\\WINDOWS\System32\drivers\stream.sys,
C:\\WINDOWS\System32\drivers\USBAUDIO.sys,
C:\\WINDOWS\System32\ksproxy.ax,
C:\\WINDOWS\System32\ksuser.dll,
C:\\WINDOWS\System32\wdmaud.drv,
all version 5.2.3790.1830
Hope this helps everybody else with this problem.
May 21, 2010 | Lexicon Omega Pro Studio External Sound...
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
I had a lexicon lambda installed on my old laptop. I lost my installer cd and now can't use my box in my new computer . how do I get the driver ?
Feb 10, 2010 | Lexicon Lambda Usb Desktop Recording...
Lexicon Omega will not play any sound on Windows XP
one of several install steps (the steps seem to vary depending on which manual you can find) mention checking your sound device setup in control panel. ON one machine I installed the sound devices were not affeted. On a 2nd PC they were changed from drivers installed with PC to the Lambda driver
Win XP settings->control panel->Sounds and Audio Devices then select Audio tab. Make sure the three areas are set up to use your PC's default drivers and not lambda's.
You may need to verify this again when reconnecting the Lambda USB cable. Sort of new but ran into this "issue" as well.
Found info in Lambda Studio Software Installation Guide I downloaded, step B following driver install.
Nov 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Lambda lexicon sound problems: is vista the cause?
Jul 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
325 people viewed this question
Top Lexicon Computers & Internet Experts
Tony Raia
Alun Cox
Thomas F. Schneider
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
