I have Frigidare FRS26ZNH and the ice maker starts making ice but the ice cubes are stuck/frozen in the maker itself. If I reach in and break them off they start the process off again and the cubes get frozen and stuck again. I have tried lowering the temp in the freezer part but it still gets stuck again. ANY help would be appreciated ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Yes I have the same problem. Check on ice often and find that the thermostat is overheating. The one under the ice cube tray. I am wondering if I should replace it? What do you think?
