Check that the pump is operating properly. hold the drain hose over a bucket during pump/spin make sure its a reasonable output from the pump..If not remove and clean your filter, then readdress problem as before, if still no cure then check the pump blades are free.....If all is well and pumping okay then spin should be fine providing the motor is okay......Good Luck.....
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
heatman101
