Precor 9.21 Treadmill Logo
Posted on Aug 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Precor 9.20 S that I purchased back in 1995. The machine has been running efficiently since that time! All of a sudden I get nothing when I turn it on. No lights, sound, nothing. I checked outlet which is fine. Any ideas? If you could let me know how I can get this serviced, I would greatly appreciate. Thank you. Lisa Seymour 7 Deer Run Court North Salem, NY 10560
Stephen Miller
Level 3:
  • Precor Master 1,645 Answers
  • Posted on Feb 25, 2019
Stephen Miller
Precor Master
Level 3:
Answers
1645
Questions
0
Helped
865917
Points
9471
Https://www.precor.com/sites/default/files/manuals/Owners-Manual-164_920920s_19940901_ENGLISH.pdf http://www.buyfitnessonline.com/product_info.php?products_id=1015
Lisa if you go on the internet and type in people that service Precor products I am sure you'll find several of them here's a manual that might be some help.
1 Related Answer
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on May 20, 2010
SOURCE: Hi, my Precor 9.21 treadmil was working fine,
Unplug unit remove motor shroud take a look at incline motor frame assembly, by the sound of it maybe metal fatigue failure disengaging the incline motor itself and could have damage it. This would be my best guess if so contact Precor.
No friction on my Precor EFX 546i.
Contact Precor direct. Details at the bottom of the page. It uses a non-standard method of resistance.
https://www.precor.com/en-ca/efx%C2%AE-546i-elliptical-fitness-crosstrainer%E2%84%A2
I have a precor 92.1i unit and it is emitting black dust from the back left quarter. I have inquired at the store where I purchased the unit several years ago and they advised me that there had been
If you really have a 'black dust' issue, your machine would be at least 7 years old - if it is less than 10 years, the parts would be under warranty, assuming you bought it new. One or both rollers and the walking belt would need to be replaced. You were advised to call Precor - did you? I am surprised the retailer did not offer any help - this seems like poor customer service.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
1helpful
2answers
Loose belt
tighten the back bolts to check tension lift the sides of the w/belt in the middle . sides should be 2-3 inches high
1helpful
Treadmill precor 655 runs suddenly fast then error
speed sensor error
check clean or replace
6helpful
4answers
My Precor 9.35 treadmill keeps shutting off. At first I thought this was due to use or it getting overheated. But, today I turned it on several times and it would shut off as I was walking on it. The...
Is it on an extension cord? Take it off any extension cords and make sure it's on a dedicated 120v circuit. No other items on the circuit. Also, how old is it? Precor made a bunch of the 9.3x series from 2002-2005 with an aluminum tail roller that can cause problems. Check the back roller. Is is silver and non-magnetic? if that's the case, you have an aluminum roller and you need to contact precor. If you're the original owner of the machine, they should warranty the replacement of the parts, if not, you'll have to buy at the very least a running belt and new roller.
1helpful
2answers
Belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
1995 vw jetta vr6 just purchased for son when
Transmission solenoid needs replacement.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
