SOURCE: paint inside microwave oven, Can it be repainted ?
Yes. You need to clean it, sand it shiny, then clean it squeky again.
Then you can get high temperature appliance paint in spray on brush-on form from local appliance part store or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: GE microwave oven - f3 error
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: I have a lg lmv
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.......
Hello & Welcome to FixYa
Microwave not heating could be due to a faulty door switch or an internal blown fuse. Check out the parts for your microwave from this link--- Link. Please get back to me if you have any other questions.
Kevin
