Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
546 A Unstable fusing temperature
The fusing temperature varies 50°C or
more within 1 second twice
continuously.
• Thermistor defective(temp. senzors in the fixing unit)
• Poor connection of the fusing unit
• Power supply unit defective
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
did you turn the dial to light the display? if so the back lights are out on the display or the ballest is bad. you need to replace the diaply. have a tech come out.
press the user tools button on the op panel. on the screen press counter. you can either view the counter on the screen, or press print counter, and it will give you a hard copy.
the 2nd way is to look behind the front cover, probably behind a piece of tape, on the right side, about half way down.
