Posted on Feb 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My device cant open the disc tray please advise me on what to do
Nanny
Level 3:
Genius:
  • Audio Player... Master 2,351 Answers
  • Posted on Sep 20, 2019
Nanny
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989319
Points
7262
First, verify no locking software is installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray.
Then, if you are running Microsoft Windows, open My Computer, right-click the disc drive icon and choose the option to Eject.
Anonymous
Level 2:
Novelist:
  • Expert 149 Answers
  • Posted on Feb 16, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
149
Questions
0
Helped
73178
Points
482
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
How do i open the disc tray on my laptop
Presuming you are talking about a CD-ROM drive, you should first check your manual for information on operating the drive. There are many ways drive trays may be opened. Sometimes there is a button on the laptop that has the standard symbol for CD eject on it that will open the cd tray. Sometimes, there is a small button on the cd-tray itself that when depressed will cause the tray to open after a small delay. This all presumes that you don't have a tray-less
CD drive, that is just a slot on the side of your laptop. If the CD tray is stuck, because of some problem, look for a small hole on the face of the CD tray. Take a straightened out paper clip and push it gently STRAIGHT into the hole until you feel it stop against a bar. Push just a little harder, and the tray should pop open. This latter procedure should only be used when all other methods have failed to open the CD tray.
Cant open disc tray
Is there a pinhole on the front of the tray that allows you to trip the release with a paper clip ?
Thanks for giving me the reply.I am not in a position to play any disc because the disc tray is stuck up in the system and does not open.I had got the lens pick up unit changed a few months back from Sony...
Hello
The fault now is with its CD mechanism. It may be either by borken loading belt, of the trouble with the gear wheel set that loads and unlods the disc tray. OK.
2helpful
Our cd changer will not open or play and I need the CDs out. Please advise
You need to open your player cover to get your disc ( Please unplug the power prior to do this). The main problem is on your mechanism system that prevent you open / close the disc tray. So please check the motor of your mechanism and its gears for malfunction, then get them fixed before retry your player. Regards
1helpful
Tray closed, but keeps saying tray open
You are having tray sticking problems, you can solve this temporarily by keeping a disc in the tray at all times, even when the console is off or you can give the console a gentle pat close to the front part where the disc tray is, not advisable though because the 360 already has SMD dry joint problems, do this occasionally, try and remove dust also around the grooves under the disc tray, hope this helps
7helpful
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 • iLO DVDR04
2helpful
The tray to my DVD player would not open. It says
Hi there! First of all, what is the brand name of the DVD Player? Don't know what advise you got but here are a few suggestions. The most common would be the little black rubber belt may have snapped or is worn out. This will result in total mechanical failure. The tray opens and closes and the the mech inside also needs to lift to bring the eye to the disc to start reading. If this motion inside does not occur when the tray is closed it can say " bad disc" or "blocked".It may also be a processing fault which in most cases will not be economical to repair. My advise is to first check the belt. Depending on the value of your machine it may be worth referring to a repairer. Regards and good luck, JUS004.
4answers
Disc tray frozen in closed position
Unplug it for a few minutes to reset it and then plug it back in again.
 Grubhead
Grubhead
SmartAviator
SmartAviator
