Hi my lg lcd model no 42LB9DE works fine apart from 1 tv channel has perfect pic but no sounds have re-tuned tv many times to no avail... any ideas ? Tv antenna is is proper working order only 1 channel i thought if u get perfect pic on any channel the sound would b ok aswell.
regards
craig
Re: Hi my lg lcd model no 42LB9DE works fine apart from...
By reading your problem the main thing is that your tuner of the tv is faulty or it can not tune the specific frequancy of the channel and its audio frequency just replace your tuner card
the LG User Guide can be found here: Download Manuals ,
if manual fine tuning will not clear the problem for you, you may have a signal reception issue which is causing the problem,
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
? 2:07
https://www.youtube.com/watch?v=Tk7EUAEncsQ
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
May 24, 2012 - 7 posts - 5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound. You can go into manual tuning and store it.
I had the same problem with the same unit when I first bought it a few months ago.
First up remove the DVD. If the TV stations do not appear within a couple of seconds press the "TV" button (top, second from left) on your remote control.
TV SETTING 1. Press the MENU button. 2. Use or button to select the TV setting menu, then press or button. 3. Use or button to select the Channel no. setting and use the or button to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts). 4. Use or button to select the Tuning mode and use the or button. 5. Use or button to select the Auto tune and press or button to confirm the selection. The unit will immediately search through all possible TV channels and store those channels with signals in memory. After this is complete, the unit will switch to the first channel found. 6. To exit the MAIN MENU and return to the normal screen, press the EXIT button. Note : In DVD mode, this option is not available. Remarks: 1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode. 2. Tuning mode : Air or Cable mode are available. 3. Auto tune : Searches for usable stations and stores them in memory. 4. Skip : ON - Skip weak channels. OFF - No channel skip. 5. Fine tune : The frequency changes to allow fine tuning. 6. AFC : Auto frequency control. 7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP). 21 TV SETUP MTS (Multi-channel Television Sound) SETTING This feature allows reception of sound other than the main audio for the program. 1. Press the MENU button. 2. Use or button to select the TV setting menu, then press or button. 3. Use or button to select MTS menu, and press or button to select the options (Mono, Stereo, SAP) 4. To exit the MAIN MENU and return to the normal screen, press the EXIT button on remote control. Note: • MTS only operates while in TV mode. • The SAP (Secondary Audio Programs) feature allows a TV station to broadcast other information, which could be audio in another language. RESTORE SETTING If you reset the TV to the factory settings, all your present settings on picture & sound will be erased and replaced by the factory’s default settings. However, picture setting in PC mode and parental setting will not be erased.
Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
Press the BLUE button to display the MAIN MENU.
Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
Press the RED button to start the auto tuning process for all available digital channels.
Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time. You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information http://www.freeview.co.uk/_retuneinfo/ If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box. For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/ For specific model information visit http://tvretune.co.uk/productmanuals/
