the Krups instruction manual is useless in this matter but if you do have some mechanical insight this is not very hard. You will need some tools, e.g. an Allen wrench to remove the housing lid.
Anyway, you should not have to clean the grinders very often, perhaps once a year is enough. It depends on the quality of the coffee beans you use; the more 'oily' beans the more frequent cleaning is required.
I would not use water to clean it, rather a small stiff brush (e.g. an old tooth brush), but if that is not enough, water will have to be used.
If so, be sure to assemble the grinder only after the burr is completely dry.
Check the link to Home Barista where a very similar grinder is shown, that should give you an idea about what to expect during the cleaning process.
Good luck;
Villi
Home Barista com
