Question about Braun IRT3020 Thermoscan Ear Thermometer
I have a Braun Thermoscan IRT 4520/IRT 4020, type 6022/6023. Was purchased about 5 months ago. Went to use it, it turned on showed all the visual it can on screen then turned off and has not turned on again. Have since then, replaced new batteries about 3 times now, just in case. Please help am living in Australia and it was purchased in New Zealand.
  • Anonymous Mar 22, 2014
    It is type 6022. It was still working last week. It suddenly do this blinking when we turn it on.
    New Friend:
  • 8 Answers
... call Braun ThermoScan customer service at 1-800-327-7226
Posted on Feb 19, 2011
    New Friend:
I had the same problem and this is what i did to fix it. Open it up and you will see the battery connectors may have worn away the contact points on the circuit board. Simply bend the connectors so they touch a different part of the contact point.
Posted on May 25, 2013
    New Friend:
I have braun thermoscan error display how to fix it
Posted on Jun 10, 2012
SOURCE:
Keep gettinG LO thermometer when taking my son's temp. but quite Ok with others
The actual temperature may be below the calibrated range of the thermometer.
Sep 22, 2016 | Braun Irt 4520 Thermoscan Ear Thermometer
Why won't it turn on?
Inspect the battery contacts for a little oxydation sometimes if its on the battery-spring contact it can happens OKS 1110 or Molykote 111 are very good protectors on battery contacts everywhere it will give long lasting protection also on the both contacts of the battery self.
In rooms with moisture it gives long lasting protection for energy-efficient appliances where batteries longer than average to be placed.
Nov 16, 2015 | Braun Irt 4520 Thermoscan Ear Thermometer
4 year old braun thermoscan IRT4520 having some problems
is the drawer that its stored in, in the bathroom? the humidity or moisture could affect it. I have had mine for 8 yrs and works perfectly. Are you placing the probe covers on correctly and waiting for it to click or a pop before inserting into ur ear.?
Jul 03, 2012 | Braun IRT3020 Thermoscan Ear Thermometer
We have the Braun 6022 thermometer. It is reading in C so temps are coming up (ex. 37.1 C) how do we get it back to F
If you whish to switch from Celsius to Fahrenheit, proceed as follows:
(1) Make sure the thermometer is turned off.
(2) Press and hold down the Start button (IRT 4020)
or the «I/O» button (IRT 4520). After about
3 seconds the display will show this sequence:
«°F» / «SET» / «°C» / «SET» ...
(3) Release the Start button / «I/O» button when the
desired temperature scale is shown. There will be
a short beep to confirm the new setting, then the
thermometer is turned off automatically.
Mar 04, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Can you change the temp reading from F to Celcius on a Braun Thermoscan 6014?
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
Feb 28, 2011 | Braun Health & Beauty
Need to convert C to F
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How fo I change the degrees from C to F degree ?
Feb 10, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Braun IRT3020 Thermoscan Ear Thermometer Logo
5,526 people viewed this question
Top Braun Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Braun Home Expert? Answer questions, earn points and help others
