KitchenAid PRO LINE KPES100PM Espresso Machine Logo
Posted on Feb 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am needing to replace the solenoid valve in my kitchen aid pro line espresso machine. kitchen aid does not carry the part. any idea on where to get it?
Piers Carter
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 46 Answers
  • Posted on May 31, 2012
Piers Carter
Expert
Level 2:
Night Owl:
Answers
46
Questions
Helped
15280
Points
115
Hi I have brought parts for mine from a place in Germany they are happy to ship to the UK but the shipping is quite expensive they have the 3 way solenoid for 51 euros on their website.
here is a link at mediafire.com to a pdf of the web address as it has non English letters this website will not allow me to post it directly also a link to the parts list I posted on rapidshares.com
http://www.mediafire.com/?6utm0xi5wypcqhr
https://rapidshare.com/files/2923830445/Kitchenaid_5KES100_Repair_Part_List_-_8212198.pdf
2 Related Answers
Anonymous
  • Posted on Mar 24, 2009
SOURCE: Parts for the Bodum Granos Espresso Machine
If you have a receipt, there is a 2 year warranty on the machine. Bodum will replace it with a new one.
Anonymous
  • 34 Answers
  • Posted on Feb 01, 2010
SOURCE: coffee maker wont turn on
maybe you bought a false one.
try bringing it to a specialist, to a technician. or bring it where you bought it.
or maybe you a new one.
try this link. hope it will help you with your concern.
http://www.coffeemakerwizard.com/4-cup-coffee-makers.html
Espresso machine won't pump when brew switch pushed. Pump runs when steam switch pushed. I replaced boiler fuse and pump fuse. Could it be a faulty brew switch? Have also de scaled and replaced the brew...
All Expresso machines have hoses that carry the water from the reservoir to the dispensing valve. These get old and cracked or clogged over time. Try to locate the owners manual on line to see the parts inside on a diagram. Then, after it is unplugged and dry as you can, TAKE IT APART! Don't worry, just lay out some paper towels and take pictures with an iphone or digital camera for each step. Most machines have notches hiding little clips that must be pushed to open the unit. Use a thin, butterknife to press these and that section will open, revealing the hoses and wiring. Do not detach any wires unless you code them with tape to put them back. Then, clean or replace the hoses and check the clamps and anything else that looks odd or wrong from a leak or bad wire. If its a bad wire- THROW the unit out! Not worth a fire in the kitchen. Good luck
Can i backflush my 2002 Steel Uno Pro
You need to check if you have the solenoid valve, if you do, then back flush regularly to avoid group blockages.
You would want to descale regularly as well to avoid the solenoid blocking.
JURA descaling tablets
3helpful
My Kitchen Aid Pro Line Espresso Machine has stopped heating the water on the espresso side. It still pumps, but it is not hot. The steamer side works fine.
Hi I have posted a service manual and a parts list here
https://rapidshare.com/files/655646388/kitenaid_service_manual_5KES100.pdf
It sounds like the boiler element or maybe the thermostat. You have to take the top part of the machine off to get a good look at the water boiler.
I have uploaded a not very good strip guide that I got from the internet, I have used it but it makes thing overly complicated to my mind, but here it is anyway.
https://rapidshare.com/files/3189994876/KES100_strip_guide.zip
It has written instruction that relate to two diagrams in the PDF.
5helpful
2answers
Hi, got Kitchen Aid Artisan Espresso Machine. 5y old. Machine just started to brew coffee way to fast. Too much water coming too fast. Normal amount of coffee ready in 5 sec instead of 15-20.... Is this a...
Hi all, got a Artisan 5KPES100 and I'm not getting any water thru' the espresso boiler. Machine is making an occasional noise & sometimes just releasing a bit of steam thru' the espresso boiler, but no water. Have replaced the water pump, but still no water being drawn from the water tank. Hose is NOT kinked & there IS sufficient water in tank. Could it be the solenoid? Can I swap over the solenoids(coils) to check as frothing boiler is still producing water & steam? Any ideas would be magic.
Recently moved to Australia. Is there anyway I can get my much loved 120V Kitchen Aid food processor rewired for Australian 240V power. Model No: RKFP740 GC Step down transformers are expensive and ugly...
Without step-down transformers you are out of luck. I am sorry. I know the transformers are ugly but they are cheaper than replacing your food processor and espresso machine. One thing you could do is to contact Kitchen Aid and ask them if the motor can be wired for 240V. If not, ask them if you can purchase the 240V motor for your processor and replace it directly. As for the espresso machine, no idea...sorry.
2answers
Coffee maker wont turn on its a kitchen aid pro line
Check your gfci plug/breakers. If its not the breaker there is a thermo resistor inside the coffee maker. You can find them at your local Radio Shack.
2answers
1helpful
Need a manual on Kitchen AidArtisan espresso machine KPES100PM, that I can print out Lars
HELLO THERE: PLEASE TRY THIS OK? and dont forget to rate this for me it helps me out so i can help you all out more best regards mike User manual KITCHENAID - User guide KITCHENAID - operating instructions ... KITCHENAID, user manual, user guide KITCHEN, KITCHEN AID, Washing : Washing Machine, ... user manual KITCHENAID MACHINE A ESPRESSO ARTISAN - operating instructions , ...safemanuals.com/brand-user-guide-instructions-owner-manual/KITCHENAID - 53k - Cached
Astoria SAE 1 trickle of water from hot water faucet
Some models have an economiser valve, which mixes hot water from boiler with cold from inlet line, that could be closed or obstructed. The line from the boiler to the solenoid or the pipe inside the boiler could be blocked.
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
