Hi, There are several possiblities of what is happening. Since I am not there in person I will go through the steps I would ordinarily do to determine what was happening. Here is the sequence:
If the dishwasher is set up for the heavy duty, "sani-cycle" type of cycle. Then it may take quite a bit of time to start running. The reason being is that the heater in the water tank is heating up the water to above 140 degrees.
To test this, cancel the existing cycle and start again shutting off all forms of pre heating, etc.and see what then happens.
The other option would be that the timer motor (not the cancel cycle part) has failed. Since the machine appears to be new, I would get it repaired under warranty from Frigidaire if this applies.
Hope this helps,
Best Regards,
Mark
Hi
F21 error means that the drain time has exceeded 8
minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to
clear the display. If errors still remains then please check the drain hose and
make sure it is not plugged or kinked. Disassemble the washer by removing the
back from the washer and check the electrical connections at the pump and make
sure the pump is draining. Also inspect the pump filter for foreign objects.
Before disassembling remember to turn off the power and disconnect the washer.
If it still doesn't help then there is an issue with the pump and you'll need
to replace it. Hope this helps... Please post back if you need more
information.
Daniel
