Tilia FoodSaver GameSaver Turbo White Logo
A
Anonymous Posted on Feb 16, 2011
I have the foodsaver professional II and it is not vacuuming. It will seal but not vacuum. I press start and the motor comes on and the first green light comes on but then nothing. It just runs forever without vacuuming at all. I have to press the off button to get it to stop. No other light, lights up besides the first green one. I've tried everything.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1038
Points
Check the gasket. If it has any depressions in it it will not form i tight seal. I removed and flipped mine over and it now works great!
  • 47_brian Apr 16, 2011
    Vacuum pump does NOT start. Last three green lights flash on/off.
1helpful
2answers
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
5helpful
5answers
Foodsaver Professional II locked up. 3 green lights blink on and off. Is the problem fixable?
I completely diassembeled my unit and could find nothing wrong. I reassembled it and had the same problem.
In my opnion the controlled board has failed; time to guy a new Foodsaver.
The small black rubber covered hole on the left side of the vacuum channel is not the reset button, it is the "lid closed" button.
The seal is not the issue as the lights start blinking right after you turn the unit on.
I have a Foodsaver 2840 that will vacuum and seal, but not seal alone. The manual button does not work (though it worked earlier today). I have tried everything. Any hints?
Hi donnaj615...
Start the vacuum and then immediately click on the seal button...
I have a 750 that does the same thing...
Please take time to rate me
17helpful
3answers
Foodsaver V845 is not sealing? vacuums okay, but won't seal bag.
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
2helpful
The V2240 does not seal or vacuum at this particular step. The motor runs, the unit buttons are working but the vacuum, sealing action does not work..... Any ideas ..... And yes It was plugged in !
It's possible that liquid is getting into the sealer or the seal is dirty. Here's a link for a pdf that explains possible problems and solutions.
http://www.foodsaver.com/Manuals/MANUALS/T000-32030_44_65900646.PDF
Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
3helpful
3answers
V3460: no response when pressing seal and inserting bag. What should I do? Thanks
  • Assuming that the unit is plugged in and the plastic bag is in the proper position.........
  • Press firmly and equally on both sides of the cover (where the three raised ridges are on each side). The 2 micro switches that start the vacuum motor are located there and require firm pressure to operate properly.
22helpful
4answers
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Top Tilia Kitchen Appliances - Others Experts
john h
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
