Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
SOURCE: microwave will not heat food
I have the same problem and have figured out the following:
Most likely it is the magnetron - common problem for GE's. Replacement part list price is around $180 but you can find on ebay for about $80. Replacement is "doable" but tricky because the oven needs to be removed to replace the part. The GE replacement kit part # for magnetron and stirrer is WB27X10489. Expect a service tec to charge at least $200-$225 to make the repair so complete replacement of microwave might make more sense...unfortunately.
SOURCE: microwave has power but wont heat food
Nothing to do with programing if it doesnt heat you have a bad magnaton or a bad capacator. I work on panasonic microwaves every day.
SOURCE: My microwave oven isn't heating my food.
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
