If it is an hd compatible tv the is has to have either an hdmi port or a dvi port. Our old projection tv was hd but before the current hdmi format so we had to use an hdmi to dvi conversion cable. If it doesn't have either of these then it probably isn't hd compatible.
Most LCD tv's built in the last 4 years are HD compatible. Most cheaper brands tv's are 720 HD and some are full HD 1080 a little more money. Since their is no more analog broadcast as June 2009 all tv's manufactured around 2006 started incorperating the digital tuner (DTV) along with the analog so that the tv would still receive analog broadcast while the digital transistion was ongoing. All tv's with a Cathode Ray Tube (glass picture tube) are not HD compatible. First you will have 1 or 2 ports on the tv ethier on the side panel or rear panel of the set. They a marked HDMI 1 HDMI 2 or HDMI A HDMI B. If you have these ports your set is Hd Compatible. You may also need to upgrade your cable or satelllite equipment and subscribe to a HD package to be able to get HD service. You will need a HDMI cable to connect your cable or satellite receiver to the HDMI port on you tv. Call your local cable or satellite provider for options to upgrade to HD. Most over the air broadcast stations depending on your area transmit some stations in HD free of charge. A good quality outdoor antenna works best to give you stable signal. You may need to change the settings of the tv as some sets default to the 480i this is the standard digital signal.
These units are not HD sets. So if you want HD sorry to say you will need a different TV. If you can live without the HD these TVs have a great picture thats as close to HD as a regular set gets.
that tv has 3-inputs digital comb filter
component video input
tv,vcr,and dvd
and also a S video input which can be connected to hp for video transfer.
yes it is compatible.
The instructions for your TV set should answer that! From what I remember, I believe your set is not HD compatable. I am guessing from memory with this.
HD ready?? NO - - Compatible? Yes but you'll need the converter.. The US post office will be giving away coupons for the converter. Google search the HD converter issue and you'll have a wealth of information.
Bill
The Sony "S" series is not HD compatible in any way. To see an HD program you would require an HD down-conversion box. This would make the pictures look like regular TV, but may have some distortions because of the 16:9 scan ratio from the HD programs, unless you model series is 16:9 compatible.
