Sir i have samsung S3500...
1.camera showing please wait and phone get hanged
2. i cant here voice of another person on call
3.its speaker not working
i have shown to various repairig shops but they said its impossible to repair
service centre is not accepting my cell as it was opened......
respected sir, you have not written the company name of your sim card, and in which country you live. balance catalouge for Indian famous telecom company are:- 1#reliance=*367# 2#Airtel=*123# 3#Bsnl=*123# 4#Vodafone=*144# or *141# 5#uninor=*222*2#
if you are still facing problem then contact customer care of your respective sim care. or dial Indian free helpline no. 198 follow the voice and talk to customer care. they will help you Guranteed!
You have 2 problems there. First, the error from the camera states that there is a problem with the camera's physical connection. It is telling you that the cable/wire that activates the camera is either loose or damaged.
With the loud speaker working and the earphone not means that the speaker is also either loose or damaged. Both the speaker and camera are on the same area in the phone and thus have a connection problem.
You have to have it checked with Samsung's Service Center.
Software End Possibilities:
It happens some times that due to some unknown reasons, the voice is reduced to a low range in order to protect the speaker from getting damage... Try checking the voice/ear piece volume settings and if the problem still persists..Try resetting the handset to FACTORY DEFAULTS ( Do make sure to back up your personal data before doing so).
Hardware End Possibilities:
If the handset is ever repaired or is in use for a long time, there are possibilities that the ear piece might had dust particles trapped on its diaphragm or even physical contacts may be disturbed.. Check for the dust particles and proper physical contacts....
Have a Nice day, Concerned,
first ill suggest if your phone is under warnety then kindly go for support from where you buy, it is much better to utilize your warranty claims on first priority. If your warranty is expire then do the following steps
On the side panel of your phone their is volume key button for increasing or decreasing voice check weather it is not too much low by increasing the volume
you can also check your phone speaker by recording your own voice in , just find this icon in your main menu Record your own voice and listen if you are getting your voice clear. or play any ring-tone if your listening any sound from the speaker that mean your speaker is okey.
Note : we often get these problem in mobile communication that we can listen voice of a caller or caller cant able to listen our voice it is because of the disturbance in communication signals, or low signals in high traffic areas.
From all of the above attempts you still not getting any voice from your phone speaker then might be your speaker is not working and you have to replace it , contact authorized samsung hardware support and change your phone speaker .
Open msn Plug webcam in Click (>) show menu > tools > audio and video set-up > run through mic and speaker tests > next > set your camera as defaut and adjust settings > finish
Hi, simmipriya i think you have a problem of camera settings, firsstly you have to check that which storage device are you using for the storage of your photos, if these are saved in phone memory then change it to memory card, as j600 have only 17 Mb of memory space 1.Go to options 2.Click on serial 7 which is camera settings 3.After that click the upper arrow key or just go to default storage then click the right arrow key to change it to memory CARD then save it i think this will resolve your problem hope you will enjoy to continue with your mobiles camera
hey!! due to high frequency sound... the speakers of ur phone has been damaged...... please get it repaired from any repair centre..... it may cost between 100-150 rs.
Normal
0
After you install Skype and have it operational with your
ID. Go to "TOOLS", click on "OPTIONS," Then go to
"Audio Settings" and click on it. Make sure both the Microphone and
Speaker's are correctly chosen.Then
"make a free test call." Wait till the voice tells you to
record. Then when finished talking wait for the test persons voice to
insure your audio transmission is working. Then go back to options and
test your video settings. Click on Video Settings and proceed to set up
you video camera. Also, you can visit this site for additional
information to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
