Boss ME25 Guitar MultiEffects Pedal with AC Power Supply Samson HP10 Headphones and (2) Sonic Sense Instrument Cables Logo
Posted on Feb 15, 2011
How to reset the pedal 25 ME? thank you.
mafia_g_net
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 15, 2012
mafia_g_net
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4272
Points
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed.
Never turn off the power while factory reset is in progress.
BOSS ME-25 SCHEMATICS
Request the schematic diagrams from Boss.
Which type of volume controller I can purchase for korg x50
Often as a not a simple volume pedal will suffice, available as a stand alone item or a feature of an effect pedal like the Boss ME-25
Oct 31, 2017 • Korg Music
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
2answers
Adapter polarity
Boss ME-25, use polarity like boss stompbox.
+ voltage at the ring, and - voltage at the center pin, of the adapter
connector.
At ME-25 DC socket:
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 • Boss Rc 50
Fix boss me-25
Is the power supply correct and power plug fully seated into the pedal? Are the other plugs the correct length and firmly seated?
My boss me 25 pedal's sound isn't as clear and good as the demos' sound. My amp is a randall RT100 which is a valve amp and my guitar is an LTD with the custom pickups. so the problem is the setting i'm...
I have the Boss ME 50. Here's things to try. Use wall outlet to power the 25 instead of batteries. Have volume on amp up, volume on pedal all the way up, volume pedal all the way up(depressed), no gain on amp(use clean channel or clean setting if only 1 channel)effects on amp off(reverb, chorus, delay, boost, etc.) mid range knob below 5. only 1 pickup on, guitar tone knob all the way towards treble. If this puts you in the ballpark you can then make slight tweaks to any of these settings. What we're trying to do is not run a dirty sound from the pedal board into an amp with dirty settings. That double dirt often causes a muddy sound. Aside from that you can back off on various effects in the patches. My 50 has a list of the patches and factory settings, so if the drive, for example is set on 8, I might back it off to 4, or the compressor, or the delay, etc. If you like the sound save it. If not continue on. Start with the amp 1st. Higher output tubes(such as JJ's produce a cleaner sound. Also the demo you heard was not coming from your guitar speaker which may not be on the clean side.
6helpful
How to reset my Zoom G1 Guitar multi effects pedal
Here is a link:http://s3.amazonaws.com/samsontech/related_docs/G1_G1X.pdf Pay attention to page 25 Restoring Factory Defaults.
8helpful
4answers
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
