Polycom C100S Logo
Posted on Feb 15, 2011
Hi, my polycom C100 is not working. Operating system does not regnize it. The same in my windows XP notebook, and Windows 7. I don't have any drivers. I believe I need to download them somewhere. Thanjs
1 Related Answer
Anonymous
  • Posted on Feb 10, 2011
SOURCE: Need a driver for CX700
what you need to do, is update the firmware of the device.
This is a good guide:
http://www.ocspedia.com/Misc/Update_Server_Check_List_R2.htm
2answers
Is adobe photoshop elements 3 compatible with windows 7
I want to mention that Photoshop Elements 3 is not tested with the Windows 7.
If you have a windows 7 64 bit operating System then it may not even install in it. If you have a 32 bit Operating System then you can try to install it. However it may still not work even on a Windows 7 32 bit Operation System as it was not made and tested for this Operating System.
There is a probability that if you install the Windows XP mode on you Windows 7 operating system then it may work.
Check more about installing Windows XP mode here:
http://windows.microsoft.com/en-IN/windows7/install-and-use-windows-xp-mode-in-windows-7 Install and use Windows XP Mode in Windows 7
Regards
Anand
Does Polycom Lifecam 3.5 work with Both Windows XP and Windows 7?
I accessed http://www.POLYCOM.com
and used their "search" function
to look for 'LIFECAM',
but no results were returned.
So, the answer seems to be NEITHER operating system.
In Device manager, my laptop shows question mark against other devices which contains 1.Network controller ,2.PCI Flash memory,3.PCI Flash memory,4.PCI Modem. What should I do ?
You are not installed those drivers, it is very easy to fix it, go to lenovo website and download and install it's drivers, finished...
you can download these drivers from here
I selected windows XP drivers here, you may have to select your appropriate operating system
Thank you,
Rate me if you don't mind..
My advent notebook 4211-B won't start up, it turns
Hi
Its mean you windows is corrupt may be due to virus infection or some body delete the system file. ok don't worry please take the windows Installation CD and repair your windows, don't worries about your data it will safe, for repairing the windows guide book is available hear.
Select your operating system
Windows 7
WIndows XP
If my solution fix your problem give me the thumb
2answers
Can windows XP be install on HP Pavilion dv7-1132nr with Vista OS
Yes, You can dual boot Windows XP and Vista but you'll be having problem finding drivers if you install Windows XP on this computer since Windows XP supported drivers aren't available on Hp download page. HP has only Windows Vista and Windows 7 drivers for this System.
Hope this helps.
Good Luck.
Thanks for using FixYa.
I have the acer5715/5315 series abd it crashed. I had it fixed and the guy put windows 7 so now none of my acer programs work. How can I get these to work with windows 7
Operating System Windows XP Professional with Service Pack 2
Windows XP Home with Service Pack 2
Windows Vista Home Premium
Windows Vista Home Basic
Windows Vista Starter
1. Before upgrading to windows 7, you must check the specification of your acer aspire 5315.
2. Windows 7 is better than windows vista but if you are really wanted those acer programs to work. You have to downgrade your operating system from your previous operating system.
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
Weather lenovo 3000 C100 supports windows 7 ultimate?
hi go to DRIVERMAX.COM and download this software(drivermax) and install it on your computer, create an account its free and update all your drivers.
Inspiron 6000 PC Notebook: supporting operating system...
Dell Inspiron 6000 PC supports only Microsoft Windows XP Operating System. You can download Drivers and application from the link:
"http://tinyurl.com/3xc7udy"
You may also try installing Windows 7 Operating System. Please refer below article before installing the Operating System.
"http://tinyurl.com/yasa9b7"
Please check if the Hardware of the Computer is compatible for installing Windows 7 Operating System.
The Drivers for Windows 7 Operating System is not available for download at the Drivers page of the Computer. However, Windows 7 has a special feature. Most of the generic drivers will be automatically installed during the installation of the Operating System.
Thanks and Regards,
Mithun
1helpful
Need to replace the driver how can i download it
The camera is out of date and Polycom has dropped all support.
You don't mention which operating system you have, but there is a driver for Windows XP, Windows 2000, Windows 98 available at
http://download.cnet.com/Polycom-ViaVideo/3000-18493_4-63906.html
Top Polycom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
