Hello soiza4242, to find out if the "Programs" exist? do the following: If this information helped? Return and give a "Helpful Rating," please!
Click on the "Start button, and open the Control Panel."
Next select in the "Programs" category, [Uninstall a program] applet.
When the window open with the "listings of all the programs installed open; check to see if the ones you mentioned are there?"
If so, then go to the "Taskbar"
{Alt / Right} click on a empty area to open the "Properties" shortcut.
Next, click on the Start Menu [buttwhen I open the start buttom the computer does not - paul7of9_90.jpg/uploads/images/paul7of9_90.jpg" alt="paul7of9_90.jpg" class="h_mi" />
Now, click on the [Customize...] button.
In the next 'window,' there will be a "Number of recent programs to display."
View the small box with #s in it, [ 10 > or< with up / down arrows].
To "Display 'more' Programs, click to {+add} arrow up!"
Click on the OK button when finished.
This will show more programs listed in the "Start Menu."
Now? If the "Programs aren't listed in the {Programs and Features}; then they will need to be "Reinstalled!"
Thanks, paul7of9
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
