Sound like it is the dual water control only. Try filling ice maker with tap water and then let freeze. If after the ice in the ice maker dumps the cubes into the ice container and does not refill I would think the water control valve is at fault. I see your model had three different choices of water control valves and listed on this page=> Here and in right sidebar about 1/3rd down the page you will see three different water control valves. Here is your Service Manual=> LG LFX25960ST Stainless Steel French Door Refrigerator Try this test first because you mentioned no water in trays. Let me know what results you get and if you have more questions feel free to ask, Thanks, Sea Breeze
Thanks You For The Rate! If you should ever have questions let me know here or through the links at top and bottom of the page I sent you to. Thanks, Sea Breeze
it's not the water control. The line is frozen I have the exact fridge and if the house is not at 22 Degree C the line freezes and doesn't make ice
Tc 600 I'm not sure what you are trying to say here. The manual for the model number of refrigerator listed has some of the best process functions on pages 25- 27 that I have seen when it comes to ice makers. When water freezes in the fill tube it usually is because a slow leak is coming from the water control valve that is not seated properly, has debris trapped in the valve seat or the household water pressure is too low and water oozes by the valve seat. Mlennstrom seems to have been please with my solution, and did well listing model number brand and a clear description of their problem. You also can ask questions from my sites if you should need. Thanks, Sea Breeze
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
