IF the unit has a rotating base to move the plate around and that is stuck on, it may be the relay on the control board that is frozen. If that is the case you need a new control board. Since you did not post the make and model, there is nothing more to say.
the fan may keep running to keep it from overheating until it cools down, if you let it go and it shuts down eventually should be no problem, maybe 3 to 5 minutes it should shut down. fan running is not dangerous however if it never stops then the fan will wear out
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please
include your brand name and the full model number from the tag in or on
the unit, a repeat of your symptoms, as well as the answers to these questions:
When it shuts down, is there anything
still on the display?
When it shuts down, does the light still come on when you open the door?
When it shuts down, do you
still hear any beeps when you press a pad on the keypad?
Also let us know it
if fails while in use or while idle.
the timer is more than likely broken. There are no replacement parts and the mocrowave will need to be replaced...or keep the door open when not in use, and use a watch to keep track of cook times
