Usually
there must be a filter screen in the dishwasher which can cause this to
happen. It goes to the drain . If there is accumulation of food
particles in the dishwasher filter screen then draining may be
obstructed which can cause the water to be stranded at the bottom.
Usually the filter
is located at the back of the dishwasher near the drain. It is usually
held in position by means of clips. You can just pop it out.Pour some
hot water in the drain and clean the drain line also.
If after cleaning this filter also you are facing the problem of water not draining then the drain pump must have gone bad.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Humming noise is due to loose connections on drain pump or due to faulty drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Hi
Hi
Hi
Hi
Hi
