Washing Machines Logo
A
Anonymous Posted on Feb 15, 2011
Washer wont fill up during rinse cycle - Whirlpool Washing Machines
Sal De
Level 3:
  • Whirlpool Master 2,699 Answers
  • Posted on Feb 15, 2011
Sal  De
Whirlpool Master
Level 3:
Answers
2699
Questions
0
Helped
1002148
Points
8029
All rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Water fills at a trickle during rinse cycle and NEVER fills up.
check urt water inlet valve and urt water pressure swttich
1helpful
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
1helpful
The washer only fills halfway up during rinse cycle only, even on high water setting. it fill completely during the wash cycle.
Has it always done this or just recently? Some washers have lower rinse fills then spray the water on the clothes as it goes through its cycle.
Water will not fill during rinse cycle. it does fill when i start the machine but not during rinse cycle.
The rinse cycle only takes cold water so I suspect that you have a bad or maybe clogged water valve on the cold side of valve.hope this helps.
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
2answers
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
