I'm having the same problem with the red light on my Q6000Z PC not going out, no matter what position that the seat is in. Yesterday I lifted the seat to change my furnice filter and when I lower the seat light wouldn't go out and the chait would not move. and yes I did try going up and down several times. I do have a Quantum joystick controler, but I don't know how to use it. Can anybody help me? Or at least give me a website name where I can go to fond out.
SOURCE: i have a quantum 600
Sounds like you need new batteries. Assuming that the chair is programmed for a faster speed and has gone faster in the past the most likely culprit is old or discharged batteries. The charger or plug may be at fault also. Also check that the charger is plugged in and the indicator lights of the charger are on.
SOURCE: chair doesnt tilt or recline im getting a message
The AAM advanced actuator module is usually located on the back of the Jazzy 600. Remove the 4 screws holding the cover on the AAM and check that all the connectors are plugged in and not backed part way out. If the PWC is running then the joystick buss connector to the AAM and buss cable from the AAM to the base controller is OK. The other connectors usually get pulled out or at an angle and make poor contact. Check that the AAM is vertical with the mounting hardware tight on the back because there is an inclinometer in the module to sense the position of the back. If you find no problem with the mechanical mount and electronic connectors, find a technician (your dealer) who has a hand held programmer for further troubleshooting. Under the AAM cover is a bypass circuit board and jumper leads to run the actuators in case of AAM failure. Hope this helps.
SOURCE: Jazzy Quantum 600 power wheelchair - On the
THE WHEELCHAIR WILL ONLY TILT IT WILL NOT GO FORWARD OR BACKWARD USING THE JOYSTICK
