I replace my gasket with a piece of 3/8" Poly Foam Caulk Saver (found mine at Home Depot - @$2.00 for 20'). It's a snug fit in the gasket groove. Cut long enough so that the ends touch tightly. It will create a good air seal and works well.
Hi!
"I do not want to buy a new FoodSaver every year or so, because of a simple gasket problem!"
I have one just like that, but I don't use it much. The few times I used it, it worked OK.
Reading about your problem, I checked mine and noticed the gasket is just high density styrofoam. Sadly, this type of material degrades with use, moisture and mostly oil.
Then I Googled for some information and found some chatboards where it is said that this particular model does have a history of poor gaskets.
I suppose if you are using the FoodSealer a lot, it may be a good idea to upgrade to something more suitable. It will be more expensive but it will likely last you a long time.
I wish I could be more ... more encouraging and helpful.
