If you have an install disc boot to it, restart your PC hold down F12 and select the CD/DVD Drive. If it boots to disc, go to the command prompt then run SFC /scannow. This will run the system file checker and repair your files as well.
you can do either way ..the ide port will support them both ..the first one has the advantage that the operation system may be left on the first one .and the data stored on the second.this way large amound of data can be protected from hdd failure ..cause if it happens usually it is affected the one with operation system ..also you can move them easy just moving the hdd... The second will be faster cause it will be all in one .and the data transfer from a partition to another faster ..also the bus has aa larger transfer rate and communication speed..but ..just see what is the most convenient for you ..price ..and function ...depends on what you want to do ..
Hello my friend this is looks like your graphic card is dying or your power supply.You should change your graphic card but if you hear any noise let me know
Check this link out for the specs for your computer. http://www.amazon.com/Sony-PCV-RS510-Digital-Studio-Pentium/dp/B0001CWI2K?tag=retrevo-20&mode=1_1_g_0_po Just copy and paste. Right now you can get this unit for $399.00, new it ran around $899.00. But like anything else in the computer world one year you need to upgrade, two years you need upgrade, Three years you need to upgrade, forth year you need to buy a more up to date computer. I replace mine and use my others for back ups or sell them. If your selling yours and it is in good shape you could get up to $399.00 for it. Hope this helps. JimmyC
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
Check your manual for the Driver type. If it is the common AC97 - then is is available for free download - just Google for it.
Also the Motherboard or utilities disk that came with the computer should have it.
Alternatively contact Sony Tech Supp Team.
