Question about Garden
I was drilling and it started smelling kinda like burnt plastic. now when i pull trigger, nothing happens at all. the drill is a bosch 1194vsr hammer drill
    Sergeant:
    Champion:
  • 242 Answers
The drill was a bosch 1194vsr hammer drill - now it is a door stop!
You could try the repair shop, but they'll probably laugh - its burnt out and they aren't usually worth repairing. It was a good drill, but they all burn out one day. Have fun choosing a new one.
Posted on Feb 14, 2011
You can try replacing the brushes. You will have to take the back plate off to access the brush holders. See the exploded parts diagram on this page: https://www.toolpartsdirect.com/media/catalog/product/cache/schematic/images/1/4/1412002.png. This is the only way to get to the brushes. Also, you might want to test the switch with an ohm/continuity/multimeter and trace the path of electricity to make sure the other parts are not the problem. There is a way to check the armature, just google it, brushes are cheap,
Posted on Jun 20, 2019
    Sergeant:
  • 197 Answers
Sounds like you need bushings do not try again till you replace then as you may damage the armiture......
there should be two plastic slotted screw caps somewhere on the drill........remove those and a bushing will pop out replace those by ordering fron tool repair shop......should cost only a few dollars
SOURCE:
How to change brushes on a bosch 1194vsr
There should be two brush holder screws, one on each side. Unscrew them and pull the brushes out. Replace them with new brushes, screw in the brush holder screws.
Jul 31, 2014 | Bosch Drills
Hi used my dual drill last weekend and it seemed fine went to use it this weekend and it dose not work ,both batteries charge but when you press the trigger nothing happens ,I have. Power all round the...
look at the windings in the housing and if they are black not bright brown they will be burnt out Also smell the motor and you will tell if it is burnt as it will smell burnt.
Jun 15, 2013 | Drills
Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Jul 24, 2010 | Bosch Drills
D25600 does nothing when i pull the trigger
take it to a repair shop.could be broken wire in lead,could be burnt out armature,could be crook trigger switch,try a new plug on the lead
Jul 05, 2010 | Dewalt D25600K Electric Rotary Hammer
How do i change the drill bit
you will get a better response by adding more information. like its a hammer drill and the type of bits being used.
im gonna guess and assume its a hammer drill.
there is a collar at the front of the drill that will pull down / back toward the trigger as this is pulled down you can pull the bit out.
Mar 01, 2010 | Bosch Drills
No power
Check the Cable between the plug and the switch for continuity using the ohmeter or continuity tester part of a cheap multimeter. Place one lead on each of the plug contacts in turn, and the other on the other end of that wire. If this is okay, check the switch for continuity by placing each lead of your tester on the in and out contacts and pressing the trigger. If still no joy, check the brushes. If still no joy, check the motor windings for continuity.
Jun 15, 2009 | Bosch HCBG500, 5 Pc Industrial Hammer...
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
Garden Logo
164 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
