Please attempt to start the jacuzzi without any water and see if it functions. Then you can fill the jacuzzi up to 1/4th with water and check if it continues to run. If so, continue to one half full. If this jacuzzi breaks down at these water levels, then you'd need to call the manufacturer to advise on what part needs to be changed to get everything working again. Thank you.
If your hot tub is running but NOT heating then you need to look at a couple of things. First, on the topside, is the heat indicator light on? If it is on and the tub is not heating then the temp sensor or the high limit sensor is not working and need to be replaced. US Parts Center
make sure the heating element isnt touching the casing inside the heating tube. if its an indoor tub, make sure the filtration cycles are not set to constant. constant filter cycles on an indoor tub will generate residual heat from the circ pump running 24/7, causing tub to heat past 104 degrees
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker. If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such.
once your tub has cooled down for 10 mins or so it will turn back on.
the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on.
if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
It sounds like the problem is in the main control box. Since the tub shuts down after reaching 110 degrees, the high temp sensor is doing its job. This sounds like a job for a qualified professional. Do get a price for the service call as they are usually expensive. Circuit boards start at 200.00 and go up.
