For Karcher washers with the Honda GC series engines it is common for them the engine to lug under pressure. For the first few minutes while it is running try keeping the choke set to about 50% - 75%. This will often help the issue. If it does then just give you washer a tune up with a new spark plug, air filter and engine oil. That will solve this issue in most cases. If it does not you will need to pull the carb and remove the main jet in the carb. It is common for them to get debri stuck in them. Use a micro drill bit to clean the main jet and re-assemble.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
