Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a Nokia E63 Mobile phone and it hangs once in a day. Somtime it hangs for three to four times and it starts automatically after hang. After restart it work fine for the timing. Kindly give the solution for the same.
antonio barbosa
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 137 Answers
  • Posted on Feb 14, 2011
antonio barbosa
Expert
Level 2:
Cheetah:
Answers
137
Questions
0
Helped
26561
Points
427
Aply the factory reset and it will work ok.
My imei number is 359319022387949
Hi, What code are you asking for? If it is a security code, The default code must be 12345. If you have changed it and forgot it, Take your mobile to a Nokia Priority Store. They could do a master reset to your mobile. This would restore your phone with default factory settings.
If you need a network restriction code, You can get it from www.wickedunlock.com/nokia-e63/rs11wp9/ at affordable cost.
UNLOCKING STEPS FOR NOKIA E63
1 - Switch on your Nokia E63 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E63.
3 - Compose #pw+CODE+1#.
4 - The Nokia E63 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E63 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E63
If i click my camera it's start to hung my mobile nokia e63!what would i do?to fix my camera??
If you have F-Secure Anti-Virus installed and the "advanced process monitoring" option of DeepGuard feature enabled, the contacts, calendar, tasks, notes, bookmarks sync may hang at 10% or 100%. A workaround is to turn off the advanced option and restart Nokia Suite.
1helpful
White screen mobile nokia
Hi.Does the phone remain white screen hang ? If yes, there might be internal hardware problem.And here if the phone working fine without showing the display,the solution is to change the LCD,if the problem persist your last chance is to contact mobile repairing shop.Thanks for visiting fixya
1helpful
My nokia e63 creating so many problems like, hang, net, downloading
reset your phone to factory settings or install latest firmware this will erase all unnecessary data from your mobile and your mobile's spped will boost up.
vote me if found helpful
My nokia e63 used to get hangged many times a day. Pls give a proper solution
Usually,the phone gets hang when you have so many data and stuffs stored on your phone memory,this might not properly generating the phone system if less free memory space left.
To fix this problem,here are some guides to do.
* you just need to erase some unused files on your phone memory.
* be sure all multi-media files are stored on memory card or if some applications,games etc is stored on your phone memory,transfer it to memory card so that your phone system saves available free space and to be able to operate other mobile functions and features.
* If the above statement does not work, you need to reset or format your phone, this will erase all files stored on your phone, so if you wish to continue,be sure to back everything before doing this method.If you are ready, just type this keys on your home screen *#7370# (hard reset method) A lock code will be ask and then enter this code 12345 (this is the default code,but if you change it before,enter your desire code. The phone will reboot automatically and after that, it will be on default settings.
I hope this solution will help you....Thanks for visiting Fixya...
I am using E63 one time my mobile hang that time i am mobile switch off few min late i on my mobile only on display light other wise not on please help
Please repeat that steps or remove the battery and sim then re fit them and hat it turn on again. If nothing change you have problem with firmware and to fix at dealer. Regards
5helpful
I have installed untrusted nokia e63 theme after installation its hanging anyhow i switched to other mode pls suggest me how to remove the hanging one theme withour factory setting
THE ONLY SOLUTION FOR THAT IS TO RESTORE YOUR PHONE INTO FACTORY SETTING. you can also save your files and contacts to your PC via nokia pc suite (the latest one) and start resetting your phone. thats the only possible way to restore your phone deleting the hanging theme.
2answers
Hanging
software problem..contact service techn
3helpful
Nokia N73 hanging
it generally hangs when u install new new softwares in it, which is sometimes not compatable with ur mobile platform.
now what u have to do is u have to format ur phone to factory settings that is the only way which is to be done in regard to make ue phone run smooth
sometime when u talk for long hours on ur cell fone , it gets heat up and ur call get automatically disconnected.
u have to reset it which is sometimes dangerous to ur cell phone, it might cause some harm to it.
There r two ways to format ur Cell Phone
1. Soft Core Format
2. Hard Core Format
1. In Soft Core Format u have to dial *#7370#    or   dial  *#7780#     this will format ur phone memory and u have to manually format ur memory card
2. In Hard Core Format ur mobile gets formatted as a tough format,     u have to keep on pressing the three buttons simultaneously(at the same time) for a long period unless u get a screen on ur phone when it asks for the region(ur country).
what u have to do:
1. switch OFF ur mobile
2. u have to press three keys at a time
    Call Button (green key) + * key + 3  at the same time
3. now dont get ur fingers off those buttons , ask someone to switch ur mobile ON (if possible make       ur cell phone placed on some table for stability) (please dont move ur fingers off those three keys       unless u get the screen where u r asked for ur region)
once u got that screen ur cell phone is formatted
NOTE: Formatting the phone with HARD CORE FORMAT METHOD may be harmful if not done in the correct way
Pls Vote for me if this solution works for u
Thank You
Vinay Ramani
India
1helpful
Hang problem
try to hard format your mobile which will help to solve this problem..but please note that you will lose all the data stored in your mobile if you do Hard Format!..try this code to format your mobile *#7370# ..Thank you!!..
k24674
ADMIN Andrew
ADMIN Andrew
