Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer
then back on again. If the problem persists, see the manual." Is
displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy
large documents such as books, make sure that you secure the clear space
in front of the tray before printing / copying. When the error message
above is displayed and if you find something is in front of the tray,
remove it. Then, turn OFF the printer and back ON again and the printer
will be ready for printing.
If you still have the trouble, contact the repair service.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Fix Canon MX328 Printer Error 6000 In Canon MP620 Printer With These Easy Steps
In order to eradicate this error code completely from your Canon printer, our Canon Technical Support team has provided a few effective solutions. You can apply them carefully on your device and check if they fix this problem for you.
In case the error still persists, you try out the following instructions from below.
Restart Your Canon Printer
Power off your Canon printer and take out the plug from the wall socket. Now plug it back again and check if the error is gone. If the error still persists, try out the other methods.
Update Your Canon Printer Drivers
If your outdated printer drivers are the reason behind this problem, you should update your printer driver immediately. Uninstall the current printer driver and restart your device to install the latest printer drivers on your system.
https://www.canonprintersupport247.com/blog/how-to-fix-canon-mx328-printer-error-6000
