Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
Posted on Dec 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The door ajar light and beeper keeps going off periodically. The light is out also. The motor is running and everything is frozen. The first time this happened, I moved items around and shut the door and it stopped for approximately 24 hours then it started over again. what could be causing this to happen?
David Emmel
Level 2:
Sergeant:
  • Expert 295 Answers
  • Posted on Dec 31, 2017
David Emmel
Expert
Level 2:
Sergeant:
Answers
295
Questions
Helped
128438
Points
781
On electronically controlled units, a light out issue may alert you to a failure situation,(minor).. Replace the bulb and see if that was the fault
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
5 Related Answers
sandy_s
Sandy Moore
  • 111 Answers
  • Posted on Jun 04, 2008
SOURCE: Defrosting???
your food should not thaw in a frost free freezer. but I can not tell you why it is thawing, sorry.
Anonymous
  • 700 Answers
  • Posted on Dec 27, 2008
SOURCE: freezer vaccum seal not working
check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
Anonymous
  • 67 Answers
  • Posted on Jan 07, 2009
freezer vaccum seal not working not freezing like it shou
jeffbvegas1
Jeff Barton
  • 520 Answers
  • Posted on Aug 16, 2009
SOURCE: Yesterday after taking something out
I bet this froze up the system and ice is present on the coils.At this juncture,simply clear items and un-plug unit to thaw out and clear ice for a few hours.It will come back to normal.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Oct 24, 2009
SOURCE: I have 16.7 upright Frigidaire Ultrafreeze
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Testimonial: "This advice seems really clear-- and I will get help from my hubby to implement it. Thanks a lot for your help! Anne"
Upright freezer door was left ajar. The alarm keeps sounding, can you tell me where the reset button is located.
Hello Deena;
My name is Peter. I am a retired field service refrigeration technician.
There is no reset for the alarm. The alarm goes off when you are not maintaining temperature.
During the time the door was ajar, warm air got into the freezer either icing up and locking the cooling fan or forming a block of ice on the cooling coils (Restricting cooling air flow.)
The best thing you can do, unless you want a $300.00 plus service call to defrost everything, is to turn power off to the freezer. Open the freezer door. Have plenty of old towels to soak up the water in the bottom of the freezer as it defrost.
You did not provide a model number which is located on the inside wall of the freezer. Every 8-10 hours your freezer will completely shout down for 20-30 minutes where only the light works and the defrost heater turns on. The ice build up is too much for the defrost heater to handle.
In some freezers the defrost mode is in the control board, in others it is a separate component that you can repeat trip using a flat head screw drive.
Jan 26, 2016 • Freezers
Alarm on door keeps peeping red light on and says door ajar
The door switch which senses when the door is ajar needs to be replaced or cleaned. See if you can make the alarm go off by pushing the switch in as far as it will go or take the switch out and by pass it by taping the wires together. There's a sensor switch for each door so try each one separately.
5helpful
The "door ajar" alarm keeps going off and the door is sealed shut?
Your door switch may be bad. Is the light on when you open the door when you manually push in on the switch does the light go off? On most fzr the door ajar alarm is set off by the door switch showing the door is open.Turn off the power by unplugging the fzr then you can pop the switch out with a flat blade screw driver if it is only a two wire you can use a paper clip to connect the two wires wrap them with elect tape Then plug the freezer back in and see if the problem clears if it does order a door switch. Some units use a vacume sensor but i believe all kenmores use the door switch. good luck
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
GE upright freezer door left ajar, temp light on.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Freezer only freezing to 20 degrez
If the door was left ajar for any extended period frost has built up on the cooling coils. A complete defrost of the freezer should take care of the problem. Normally a frost free system will clear the ice from the cooling coil when the defrost time cycle happens. However frost may have built up in areas where the heaters can not readily remove it in a normal defrost cycle and shutting the unit down with the door open for about 24 hours should clear it out.
Nov 27, 2008 • Freezers
2helpful
Servis fridge freezer
Hi ,
ngafm at your service,
If its cold and frozen it may be that the door switch that activates this light in the case that the door is ajar, is faulty.
Or it may be that the temperature is dropping to slowly for you to see it by eye!
The whole purpose of the, "door ajar" light is to protect you food from spoilage and to warn you before it gets to warm!
Door ajar or not!!!
My advice is to fix the problem now no matter if it is only the switch causing a false alarm.
Or the worst case scenario !
You need hands on service!
Bless You ,
ngafm,
please give me a good rating before you sign off.
Thank you.
Sep 07, 2008 • Freezers
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
