There is no circuit breaker on the M41. There are fuse links located on the wiring harness on the positive post of each battery. If you are not getting any power to the joystick check the joystick cable to make sure it didn't come unplugged then you can check the battery voltage with a meter set to 200 vdc and plug the leads into the charger port located under the front of the joystick put the leads into the two outter holes of the port and you should read the battery voltage fully charged it should read 25-27 volts if you aren't getting any reading then you will have to remove the seat and shroud to get to the batteries to check the fuses on the positive posts Hope this helps
