Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
A
Anonymous Posted on Feb 14, 2011
Hello -- I am having issue with this dishwasher! Water pools at the bottom and dishes are not getting clean!!!
bandman1967
Level 1:
  • Contributor 24 Answers
  • Posted on Feb 14, 2011
bandman1967
Contributor
Level 1:
Answers
24
Questions
0
Helped
6185
Points
63
Your pump is worn out. Time to get it to a repair man or get the manual out and if you feel handy be ready for some major expense and time.
1 Related Answer
Anonymous
  • 20 Answers
  • Posted on Aug 31, 2009
SOURCE: dishwasher just doesnt get dishes clean anymore.
Check your vacuum breaker. Its some times mounted up on the back of your sink. If it gets stopped up it will cause your dish washer to not drain or clean properly. Good luck.
4helpful
2answers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Asko 1996 appears "dead".....no lights flashing, won't respond to repeatedly pushing on/off button. Some water left in the bottom...siphoned it out, cleaned filters, no blockage there. Almost like it's...
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
Does not clean like it did soap dispences goes through the cycles does not seem to have the pressure
Hello there"
Please go thru this list that i have provided for you and check each item ok
It doesn't get the dishes clean dot_lineone.gif 1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, we recommend Dishwasher Magic®.
8helpful
2answers
It's like my whirlpool is not getting any water...it was working fine yesterday and today when I started it I opened it after the cycle was done - the dishwashing liquid was pooled at the bottom and the...
on the bottom of the inside remove bottom rack and you will find a plastic float. it is most likely stuck in the up position. jiggle shake , turn and it should go down and allow it to "think" it is empty to allow fill. good luck, let me know.
Dish washer gets water but does not clean the dish
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Dishwasher just doesnt get dishes clean anymore. some food left on dishes. there is always water pooled in bottom of dishwasher, but I've cleaned it out well at the bottom
Aug 30, 2009 • Dishwashers
Clogged dishwasher drain?
clean the filter, check the water inlet and outlets for blockages
1helpful
2answers
Dishes have a fine white film when useing hard water using rinse
Check the following to combat this issue.
Not enough water
Clogged spay arms
The most common issue will be a high calcium build up overtime.
1helpful
Dishes are not clean.. on top level the dishes seem to be steamy
Check the following to address this issue.
1. No water
2. Not enough water
5. Not enough soap
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Top Viking Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
