SOURCE: Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
SOURCE: I lost the remote and cant find a universal that
you can go to menu options, than find programming options.
Look for an option called "autoprogram" and select it. It will search and set all available channels.
There is universal remotes for this tv that you can find by googling "elements electronics remotes":
SOURCE: Channels 3, 4, 5, and 7 are mute. The mute button has no effect.
there should be an audio section of your tv
Go through each of your setting s and be sure nothing was changed. goto setup and reset to factory settings. your TV will do something funky and powercycle.
THAT should fix your problem.
if not, is your cable service through your VCR? if so, remove the vcr altogether and connect your cable services directly. All should now be a go.
SOURCE: I have an Element 32
I talked to the manufacturer & they said that all I needed to do was to run the channel search, uninterupted, again. I did it & everything works. Thank you for your input.
